RG-N18010-X Switch - 1
RG-N18010-X Switch - 2
RG-N18010-X Switch - 3
RG-N18010-X Switch - 4
RG-N18010-X Switch - 5
RG-N18010-X Switch - 6
RG-N18010-X Switch - 7
RG-N18010-X Switch - 8
RG-N18010-X Switch - 9
RG-N18010-X Switch - 10
RG-N18010-X Switch - 11
RG-N18010-X Data Center Modular Core Switch with Eight Line Card Slots and 10GE/40GE/100GE/200GE/400GE Line Cards
Spesifikasi Penting View More
100GE Data Center Modular
Core Switch RG-N18010-X
Up to 384 x 100GE ports, 288 x 40GE ports, and 1152 x 10GE ports, for line-rate forwarding
Line cards:
  • M18000X-48DC-CE:
  • M18000X-48CQ-CE:
  • M18000X-36CQ-CE:
  • M18000X-36QXS-CB:
  • M18000X-48XS2CQ-CB:
De-stacking
M-LAG
Clos architecture
RG-N18018-X
RG-N18010-X
RG-N18006-X
Module slots
18 (2 for supervisor modules)
10 (2 for supervisor modules)
6 (2 for supervisor modules)
Switch fabric module slots
Three fan module slots
Sixteen power module slots
Eight power module slots
Four power module slots
307.2 Tbps
153.6 Tbps
28.8 Tbps
69,120 Mpps
34,560 Mpps
17,280 Mpps
Large buffer
(W × D × H)
120.88 kg (including the fan)
52 kg (including the fan)
49 kg (including the fan)
Power supply
RG-PA2700I:
AC: 100 V AC to 240 V AC
HVDC: 192 V DC to 350 V DC
RG-PA3000I-F:
Ventilation type
Front-to-rear ventilation
≥ 200,000 hours
0°C to 45°C (32°F to 113°F)
Storage temperature
Storage humidity
5% to 95% RH (non-condensing)
Working altitude
up to 5000 m (16404.19 ft.)
RG-N18018-X
RG-N18010-X
RG-N18006-X
Virtual Switching Unit 3.0
Data center features
VXLAN bridge
VXLAN gateway
BGP-EVPN VXLAN
VXLAN mapping
IPv6 VXLAN over IPv4
M-LAG
OpenFlow 1.3.
Traffic analysis
IPFIX
NetFlow
L2 features
IEEE 802.1Q
STP, RSTP, MSTP
IPv4 features
Policy-based routing
IPv6 features
VRRPv3
IGMP Snooping
IGMP Proxy
MLDv1, MLDv2
Fast leave
Ingress/Egress ACLs
IPv6 ACLs
Port-based rate limit
Hot patching
ISSU
NSR
FRR
Source IP address restriction
ITU-T Y.1731
FTP, TFTP, Xmodem, and SFTP
SNMP V1/V2c/V3
RMON
NTP clock
Traffic analysis
Zero-touch provisioning (ZTP)
Telemetry
RG-N18018-X
RG-N18010-X
RG-N18006-X
● NM EN 62368-1
● NM CEI 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● VCCI-CLSPR 32
● VCCI-CLSPR 32
● NM EN CEI 61000-3-2
● NM EN 61000-3-3
● NM EN 55035
● ETSI EN 300 386
● ANSI C63.4-2014
● ICES-003 Issue 7
  • Select the line card.
    RG-N18018-X
    RG-N18010-X
    RG-N18006-X
    M18000X-CM
    M18000X-CM II
    M18006X-CM II
    M18000X-CM X
    Power Modules
    RG-PA2700I
    RG-PA3000I-F
    Switch Fabric Modules
    M18018X-FE-C II
    M18018X-FE-C V
    M18010X-FE-C I
    M18010X-FE-C II
    M18006X-FE-C I
    M18006X-FE-E I
    M18010X-FE-E II
    M18018X-FE-E IV
    M18000X-36QXS-CB
    M18000X-36CQ-CB
    M18000X-18CQ-CB
    M18000X-18QXS18CQ-CB
    M18000X-48XS2CQ-CB
    M18000X-48CQ-CE
    M18000X-48DC-CE
    XG-LR-SM1310
    XG-SR-MM850
    Mini-GBIC-GT(F)
