RG-S6520-64CQ Switch - 1
RG-S6520-64CQ Switch - 2
RG-S6520-64CQ Switch - 3
RG-S6520-64CQ Switch - 4
RG-S6520-64CQ Switch - 5
RG-S6520-64CQ Switch - 6
RG-S6520-64CQ Switch - 7
RG-S6520-64CQ Switch - 8
RG-S6520-64CQ Switch - 9
RG-S6520-64CQ 100GE Data Center Access Switch
Recommended for large-scale Spine-Leaf three-tier DCI scenarios, M-LAG/VSU/de-stacking for higher availability
  • 64 x 100GE QSFP28 ports housed in a 2 RU enclosure
Spesifikasi Penting View More
De-stacking
M-LAG
RG-S6520-64CQ
64 x 100GE ports (QSFP28)
Expansion Module Slots
Two power supply module slots, supporting 1+1 redundancy
Three fan module slots, supporting 2+1 redundancy
12.8 Tbps
4482 Mpps
4094
(W × D × H)
442 mm x 450 mm x 88.1 mm (17.40 in. x 17.72 in. x 3.47 in., 1 RU)
About 20 kg (44.09 lbs., including two power supply modules and three fan modules)
AC
RG-PA800I-F module
● Rated input current range: 5 A to 10 A
High-voltage DC
RG-PA800I-F module
● Max voltage range: 180 V DC to 310 V DC
● Rated voltage: 240 V DC
● Rated input current: 5 A
Maximum Power Consumption
● Max: 600 W
● Typical: 410 W
● Static: 222 W
0 °C to 45 °C (32 °F to 113°F)
10% RH to 90% RH
Working altitude
RG-S6520-64CQ
L2 Protocols
L3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing (PBR), Route-policy, Equal-Cost Multi-Path Routing (ECMP), WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, Any-RP
IPv6 Basic Protocols
IGMPv1, v2, v3、IGMP Host Behavior、Member Query and Response、Querier Election、IGMP Proxy、Multicast Static Routing、MSDP、PIM-DMv4(PIM-DM)、PIM-SMv4(PIM-SM/PIM-SSM/Enabling PIM on Layer-3 Subinterface)、PIM-SMv6、MLD v1 and v2、MLD Proxy、Enabling PIMv6 on Layer-3 Subinterface
Data Center Features
M-LAG
RDMA
sFLOW sampling
Virtualization
Virtual Switching Unit
Buffer Management
HA Design
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy and fan redundancy, and hot swapping for all cards and power supply modules
Security Features
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, and ARP check
Management Mode
SNMP v1/v2c/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, syslog, SPAN/RSPAN/ERSPAN, and configuration rollback
RG-S6520-64CQ
● NM EN 62368-1
● NM CEI 62368-1
● BS EN 62368-1
● NM EN 55035
● BS EN55032
● BS EN 55035
● BS EN 61000-3-2
● BS EN61000-3-3
● EN IEC 61000-3-3
● NM EN 61000-3-2
● NM EN 61000-3-3
● EN 300 386
● VCCI-CLSPR 32
The configuration procedure for the RG-S6520 series switches is as follows:
  • Select the switch.
    RG-S6520-64CQ
    64 × 100GE ports
    The power supply model is RG-PA800I-F, and the fan model is M6520-FAN-F.
    RG-PA800I-F
    M6520-FAN-F
