RG-CS83-48GT4XS-PD Switch - 1
RG-CS83-48GT4XS-PD Switch - 2
RG-CS83-48GT4XS-PD Switch - 3
RG-CS83-48GT4XS-PD Switch - 4
RG-CS83-48GT4XS-PD Switch - 5
RG-CS83-48GT4XS-PD Switch - 6
RG-CS83-48GT4XS-PD Switch - 7
RG-CS83-48GT4XS-PD Switch - 8
RG-CS83-48GT4XS-PD Switch - 9
RG-CS83-48GT4XS-PD Switch - 10
RG-CS83-48GT4XS-PD Switch - 11
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
3 MB
8,000
VLAN translation
4,094
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
4.3 kg (9.48 lbs)
4.6 kg (10.14 lbs)
6.78 kg (14.95 lbs)
6.98 kg (15.39 lbs)
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
RG-PA600I-P-F: 600 W
65 W (non-PoE)
810 W (full PoE load)
75 W (non-PoE)
1570 W (full PoE load)
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
27°C (80.6°F): 51.6 dB
45°C (113°F): 57.4 dB
45°C (113°F): 58.3 dB
Power supply fault alarming
Automatic speed adjustment
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
Communication standard
RG-CS83-PD Series
Non blocking
PIM-SMv6, PIM-SSM v6
Traffic policing: CAR
Allowlist
CPP(CPU Protection Policy)
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
