Spesifikasi Penting View More
De-stacking
M-LAG
RG-S6510-4C
25GE, 40GE, and 100GE ports
Slots
Expansion Module Slots
Power supply module slots
Fan module slots
6.4 Tbps
2030 Mpps
4094
RG-S6510-4C
(W × D × H)
RG-S6510-4C
AC
Rated voltage: 110 V/220 V
High-voltage DC
RG-PA800I-F module
● Rated voltage: 240 V DC
● Max input current: 5 A
RG-PD800I-F module
● Rated voltage: –48V DC
● Max input current: 23 A
Maximum Power Consumption
● Max: 650 W
● Typical: 455 W
● Static: 202 W
RG-S6510-4C
Working altitude
RG-S6510-4C
Virtual Switching Unit 3.0
L2 Protocols
L3 Protocols (IPv4)
IPv6 Basic Protocols
Data Center Features
IPv6 VXLAN over IPv4
RDMA
M-LAG
OpenFlow 1.3
sFLOW sampling
INT
Virtualization
Buffer Management
HA Design
Security Features
Management Mode
Specification
RG-S6510-4C
● NM EN 62368-1
● NM CEI62368-1
● BS EN 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● EN 61000-4-2
● EN 61000-4-3
● EN 61000-4-4
● EN 61000-4-5
● EN 61000-4-6
● EN 61000-4-11
● EN 61000-3-2
● EN IEC 61000-3-3
● EN 300 386
● ETSI EN 300 386
● NM EN 55035
● NM EN 61000-3-2
● NM EN 61000-3-3
● BS EN 55032
● BS EN 55035
● BS EN 61000-3-2
● BS EN 61000-3-3
● CNS 13438
● ANSI C63.4-2014
● ICES-003 Issue 7
    RG-S6510-4C
    RG-PA800I-F
    M6500-FAN-F
    M6500-08CQ
    Eight QSFP28 ports
    M6500-24VS2CQ
    M6500-16QXS
    16 QSFP ports
    XG-LR-SM1310
    XG-SR-MM850
    Mini-GBIC-GT(F)
