Dokumen
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
RG-S5760C-24SFP8GT8XS-X
RG-S5760C-48SFP4XS-X
RG-S5760C-48GT4XS-HP-X
Two built-in fan modules
Three pluggable fan modules
Two pluggable fan modules
Two power modules
Management port
Expansion slot
512 Mpps
488 Mpps
512 Mpps
488 Mpps
488 Mpps
688 Gbps
656 Gbps
688 Gbps
656 Gbps
656 Gbps
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
In: 7,000
Out:1,500
4.4 kg (9.70 lbs)
5.3 kg (11.68 lbs)
5.5 kg (12.13 lbs)
1.2 GHz dual-core CPU
Flash memory: 4 GB
SDRAM: 1 GB
Flash memory: 4 GB
SDRAM: 2 GB
1.2MB
Without PoE load: ≤ 110 W
With PoE full load: ≤ 1,590 W
RG-PA70IB: 70 W
RG-PA150I-F: 150 W
RG-PA70IB: 70 W
RG-PA150I-F: 150 W
RG-PA150I-F: 150 W
RG-PA150I-F: 150 W
Frequency: 50 Hz/60 Hz
Rated voltage range: 240 V
LVDC input:
DC input:
DC input:
LVDC input:
DC input:
DC input:
120 years
110 years
94 years
90 years
95 years
10% to 90% (non-condensing)
5% to 95% (non-condensing)
45°C (113°F): 57.1 dB
27°C (80.6°F): 50 dB
45°C (113°F): 65 dB
27°C (80.6°F): 53 dB
45°C (113°F): 68 dB
RG-S5760-X Series
IGMP v1/v2/v3 and IGMP proxy
Dynamic ARP Inspection (DAI)
REUP, RLDP, and DLDP
1+1 power module redundancy
Syslog
RG-S5760C-48GT4XS-HP-E:
Power Modules
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
M5000X-4XS2CQ
M5000X-4QXS*
4 x 40GE QSFP+ ports
600 W PoE AC power module
1000 W PoE AC power module
RG-PD600I-P-F
600 W PoE DC power module
Optical Modules
