RG-S5350-48GT4SFP-E Switch - 1
RG-S5350-48GT4SFP-E Switch - 2
RG-S5350-48GT4SFP-E Switch - 3
RG-S5350-48GT4SFP-E Switch - 4
RG-S5350-48GT4SFP-E Switch - 5
RG-S5350-48GT4SFP-E Switch - 6
RG-S5350-48GT4SFP-E 48-Port GE Layer 3 Managed Access Switch, 4-Port 1GE Uplink
Layer 3 Compact Access Switch for 1GE Uplink RG-S5350-48GT4SFP-E
Passed anti-corrosion tests, with the proven capability to withstand exposure to moisture, ensuring durability in severe environments
VSU, Enabling Flexible Networking and High Performance
Virtual Switching Unit (VSU) allows multiple physical switches to be virtualized into one logical unit, simplifying network configuration and architecture, eliminating loops, and improving reliability.
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-12GT4XS-P-E
RG-S5350-24GT4XS-P-E
RG-S5350-48GT4XS-P-E
Fixed service ports
4 x 1GE/2.5GE/10GE SFP+ ports
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
RG-S5350-24GT4SFP-P-E
RG-S5350-48GT4SFP-P-E
Fixed service ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
94 Mpps
125 Gbps
DDR4 1GB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
50 Mpps
94 Mpps
50 Mpps
94 Mpps
67 Gbps
125 Gbps
67 Gbps
125 Gbps
DDR4 1GB
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Unit weight
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Mounting
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
3.25 kg (7.17 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Mounting
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fixed power supply: 40 W
Leakage current
≤ 3.5 mA
Built-in power supply: 409 W
35 W (without PoE load)
405 W (full PoE load)
52 W (without PoE load)
Leakage current
≤ 3.5 mA
The maximum power is 370 W.
The maximum power is 405 W.
supported
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
Built-in power supply: 40 W
Leakage current
≤ 3.5 mA
●AC input
Fixed power supply: 409 W
Fixed power supply: 460 W
Leakage current
≤ 3.5 mA
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fanless, quiet, < 20 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-E Series
PIM SMv6, and PIM-SSMv6
Extended IP (hardware ACLs
IPv6 ACLon IP addresses)
Multiple AAA modes
BFD, NSR, VRRR, VRRP+
Basic LACP
SPAN, RSPAN
CLI (Telnet/Console)
1:1 mirroring
N:1 mirroring
1:N mirroring
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
