RG-S6120-20XS4VS2QXS 20-Port 10G (Compatible with 2.5G) Layer 3 Managed Core and Aggregation Switch
  • Rich port types, 20 x 10G SFP+ ports (Compatible with 2.5G), 4 x 25G SFP28 ports, and 2 x 40G QSFP+ ports for uplink
Spesifikasi Penting View More
Recommended aggregation switch for large-sized networks, or core switch for small and medium-sized networks. With 20 x 10G SFP+ ports and 4 x 25G SFP28 ports, the switch provides flexible access capabilities. The 2 x 40G QSFP+ uplink ports deliver high-speed uplink connectivity, fully satisfying the requirements of high-performance networks.
and Network Connectivity
Fixed por
20 x 1G/2.5G/10G SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports
One switch provides a maximum of 32 x 10G ports, 2 modular power slots, and 2 modular fan slots.
2 x pluggable fan modules, and fan speed regulating and alarm function
Power modules
570 Mpps
760 Gbps
Maximum number of ingress ACEs associated with an SVI, physical interface, or aggregate interface: 2,500
1,024
Number of VRFs
100
442 mm × 330 mm × 43.6 mm (17.40 in. x 12.99 in. x 1.72 in.), 1 RU
Weight (full load)
5.7 kg (12.57 lbs)
1.25 GHz ARM processor
Flash memory: 1 GB
4MB
< 85 W
RG-PA150I-F:
Rated input current: 3 A
Rated voltage: 240 V DC
RG-PD150IB-F:
DC input: -48 V DC to -60 V DC
RG-PA150I-F:
AC input: 90–264 V AC; 47/63 Hz
HVDC input: 192–288 V AC
RG-PD150IB-F:
DC input: -36 V DC to -75 V DC
5% to 90% RH (non-condensing)
Maximum operating altitude
5000 m (16404.20 ft.)
< 78 dB
Power module: 6 kV
Software
IP Routing
IS-IS
BGP4 and MP-BGP
PIM-DM, PIM-SM, and PIM-SSM
RADIUS and TACACS+
NTP, SNTP, and NTP for IPv6
FTP/TFTP v6
SNMP over IPv6
CLI (Telnet/console)
Syslog
IPv6 MIB support for SNMP
Telnet v6
Traceroute v6
 DNS v6
20 x 1G/2.5G/10G SFP+ optical ports, 4 x 10G/25G SFP28 optical ports, and 2 x 40G QSFP+ optical ports, and up to 32 10G ports
150 W AC power module that applies to the RG-S6120-20XS4VS2QXS
RG-PD150IB-F
Power module (support redundancy, DC, 150W ,10 A)
GE Optical Module
1000BASE-GT mini GBIC module
2.5
GE Optical Module
SFP 2.5G BIDI Transceiver-TX1310/RX1550,3km,LC
SFP 2.5G BIDI Transceiver-TX1550/RX1310,3km,LC
10GE Optical Modules
10GE LC connector module, applicable to the SFP+ port
62.5 μm/125 μm: 33 m
50 μm/125 μm: 66 m
Modal bandwidth of 2000 MHz·km for a link length of up to 300 meters
10GE LC connector module with a link length of up to 40 km, 1310-nm wavelength, applicable to the SFP+ port
10GE LC connector module with a link length of up to 40 km, 1550-nm wavelength, applicable to the SFP+ port
10GE SFP+ port cable, 1 m, including one cable and two interface modules
10GE SFP+ port cable, 3 m, including one cable and two interface modules
10GE SFP+ port cable, 5 m, including one cable and two interface modules
25G Optical Modules
0G Optical Modules
