Home> Produk> Switch> Core/Aggregation Switches>
RG-S5750C-28SFP4XS-H
Lebih banyak+
Abundant QoS Policies
RG-S5750C-28GT4XS-H
RG-S5750C-48GT4XS-H
RG-S5750C-48SFP4XS-H
GE RJ45 port
28
8 (Combo)
n/a
GE SFP port
4 (Combo)
n/a
28
n/a
10GE SFP+ port
Card slot
n/a
Card type
n/a
ETH management port
Console port (RJ45)
Console port (Mini USB)
USB 2.0 port
598Gbps/5.98Tbps
598Gbps/5.98Tbps
598Gbps/5.98Tbps
598Gbps/5.98Tbps
598Gbps/5.98Tbps
Forwarding rate
222Mpps
252Mpps
222Mpps
252Mpps
132Mpps
MAC table size
20,000
20,000
20,000
20,000
20,000
9216 Bytes
9216 Bytes
9216 Bytes
9216 Bytes
9216 Bytes
Packet buffer
32Mbit
32Mbit
32Mbit
32Mbit
32Mbit
Maximum
PoE power budget
n/a
1480W
 (w/ 2 RG-PA1150P-F)
PoE/PoE+ enabled port
Standard
IEEE802.3af/at
Dimensions(WxDxH)
440 X 280 X 44mm
440 X 300 X 44mm
440 X 300 X 44mm
440 X 340 X 44mm
440 X 420 X 44mm
3.9kg
4.2kg
4.2kg
4.7kg
6.1kg
Type
Hot swappable
Redundancy
1+1
1+1
1+1
1+1
1+1
AC frequency
50/60Hz
Rated AC voltage
100~240V
Maximum AC voltage
90~264V
Rated HVDC voltage
240V DC
Maximum HVDC voltage
192~288V DC
Rated DC voltage
-36V ~ -72V DC
Maximum power rating
140W
140W
140W
300W
2300W
Idle power rating
45W
45W
55W
100W
70W
Dissipation mode
Number of fan
Airflow
EN 60960-1, IEC 60950-1
EN 60960-1
EMC
EN 300 386
Emissions
EN 55022, EN55032
Immunity generic
EN 55024
EN 61000-4-2
Radiated
EN 61000-4-3
EFT/Burst
EN 61000-4-4
Surge
EN 61000-4-5
Conducted
EN 61000-4-6
EN 61000-4-8
EN 61000-4-11
Harmonics
EN 61000-3-2
Flicker
EN 61000-3-3
Anti-gas corrosion
0 ℃ ~ 50 ℃
-40 ℃ ~ 70 ℃
10%~90% RH
5%~95% RH
-500 ~ 5000m
MTBF(hours)
555960
513460
506320
523510
451400
Ethernet
MAC
STP
ERPS
L2 multicast
IPv4 unicast routing
IPv6 unicast routing
IPv6 feature
Multicast routing
MPLS L3 VPN
BGP VPN, IS-IS VPN, OSPF VPN
VRRPv3, VRRP+
RNS
Stream classification
Shaping
Congestion avoidance
RED, WRED, Tail drop
Congestion management
3500 IPv4/v6 rules
ACL type
ARP security
Attack defense
IP
IEEE802.1X
Web portal
Login
File
Network
Application
Hardware monitoring
RG-S5750C-28GT4XS-H
RG-S5750C-48GT4XS-H
M5000H-01QXS
M5000H-04XS
RG-PA70I
RG-PD70I
Transceiver
FE-SFP-LX-MM1310
FE-SFP-LH15-SM1310
PoC Guide
