Switching capacity: 116 Gbps
Forwarding rate: 87 Mpps
RG-S5000-10GT2MS-E |
RG-S5000-10GT2MS-P-E |
RG-S5000-24GT4MS-E |
RG-S5000-24GT4MS-P-E |
RG-S5000-48GT4MS-E |
Fixed port |
10 x 10/100/1000Base-T Ethernet ports with auto-negotiation 2 x 2.5GE/1GE SFP ports |
10 x 10/100/1000Base-T Ethernet ports with auto-negotiation 2 x 2.5GE/1GE SFP ports PoE/PoE+ supported |
24 x 10/100/1000Base-T Ethernet ports with auto-negotiation 4 x 2.5G/1GE SFP ports |
24 x 10/100/1000Base-T Ethernet ports with auto-negotiation 4 x 2.5GE/1GE SFP ports PoE/PoE+ supported |
48 x 10/100/1000Base-T Ethernet ports with auto-negotiation 4 x 2.5GE/1GE SFP ports |
Power module |
1 x fixed module |
Fan module |
0 |
1 x fixed module |
0 |
2 x fixed modules |
2 x fixed modules |
Fixed management port |
1 x RJ45 console port and 1 x USB port |
Packet forwarding rate |
22.5 Mpps |
22.5 Mpps |
51 Mpps |
51 Mpps |
87 Mpps |
System switching capacity |
30 Gbps |
30 Gbps |
68 Gbps |
68 Gbps |
116 Gbps |
MAC address |
16000 |
512 |
ND table size |
256 |
64 |
64 |
500 |
260 mm x 170 mm x 43.6 mm (10.24 in. x 6.69 in. x 1.72 in.), 1 RU |
297 mm x 170 mm x 43.6 mm (11.69 in. x 6.69 in. x 1.72 in.), 1 RU |
440 mm x 220 mm x 43.6 mm (17.32 in. x 8.66 in. x 1.72 in.), 1 RU |
Weight (full load) |
2 kg (4.41 lbs) |
2.5 kg (5.51 lbs) |
2.5 kg (5.51 lbs) |
2.8 kg (6.17 lbs) |
2.8 kg (6.17 lbs) |
ARM Cortex A9, 1.2 GHz |
Storage |
512 MB SDRAM 64 MB flash memory |
Data packet buffer |
512 KB |
512 KB |
512 KB |
512 KB |
512 KB |
Power and Consumption |
16 W |
141 W (PoE power: 125 W) |
15.6 W |
430 W (PoE power: 370 W) |
30 W |
Rated input voltage |
100 V AC to 240 V AC @50 Hz/60 Hz |
90 V AC to 264 V AC @50 Hz/60 Hz |
> 200K |
> 200K |
> 200K |
> 200K |
> 200K |
Primary airflow |
Natural heat dissipation |
Forced air cooling |
0°C to 45°C (32°F to 113°F) |
Operating altitude |
–500 m to +5,000 m (–1640.42 ft. to + 16404.20 ft.) Above an altitude of 1800 m (5905.51 ft.), the operating temperature can decrease. |
Operating noise |
Fanless |
≤40 dB |
Fanless |
≤40 dB |
≤40 dB |
Interface surge protection |
Common mode 10 kV |
Common mode 10 kV |
Common mode 10 kV |
Common mode 10 kV |
Common mode 10 kV |
Others |
Installation mode |
RG-S5000-E Series |
Feature |
Ethernet switching |
802.3az EEE |
IEEE 802.1Q (4K VLANs) |
Port-based VLAN assignment |
IP service |
Static and dynamic ARP |
DHCP client |
DHCP relay |
DHCP server |
DHCP snooping |
DNS client |
Neighbor Discovery (ND) |
IP routing |
OSPFv2 |
IGMP snooping v1/v2 |
IGMP fast leave |
MAC-based extended ACLs (ACLs based on source or destination MAC addresses) |
Expert ACLs |
IPv6 ACL |
ACL 80 |
Global ACLs |
Flow-based rate limiting at the ingress |
Port rate limiting |
Traffic classification based on 802.1p or DSCP priorities |
Eight queues on each port |
Rate limiting in each queue |
RADIUS and TACACS+ |
IEEE 802.1X authentication |
MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication |
SSHv1.5 and SSHv2.0 |
ICMPv6 |
Proxy ARP and ARP entry aging |
Hardware CPP and NFPP |
RLDP |
LACP |
Load balancing modes |
Rapid Link Detection Protocol (RLDP), Layer 2 link connectivity detection, and unidirectional link detection |
RSPAN |
sFlow (sFlow is a network detection technology based on packet sampling, which is mainly used for traffic statistics analysis in super-heavy network traffic scenarios) |
NTP (NTP client and NTP server) |
TFTP (TFTP client) |
SNMPv1/v2c/v3 |
CWMP |
SSH v1.5/v2.0 |
RG-S5000-10GT2MS-P-E and RG-S5000-24GT4MS-P-E: l IEEE 802.3af and 802.3at l Automatic and energy-saving power supply management mode l Uninterrupted power supply in hot start mode l Scheduled powering on or off PoE ports l Port priority |
Cloud |
WIS |
10 x 10/100/1000Base-T electrical ports with auto-negotiation, 2 x 1GE/2.5GE SFP ports, fixed single AC power supply |
10 x 10/100/1000Base-T electrical ports with auto-negotiation, 2 x 1GE/2.5GE SFP ports, fixed single AC power supply, ports 1 to 8 supporting PoE/PoE+ power supply, and maximum PoE output power of 125 W |
24 x 10/100/1000Base-T electrical ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply |
24 x 10/100/1000Base-T electrical ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, and maximum PoE output power of 370 W |
48 x 10/100/1000Base-T electrical ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply |
2.5G-SFP-LX03-SM1310-BIDI-I |
2.5G-SFP-LX03-SM1550-BIDI-I |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
