  • 2.5G uplink, which can upgrade gigabit networks to 10GE networks, and meet 40GE/100GE networking requirements in the future
Spesifikasi Penting
Killer Layer 2+ Access Switch
Applications
Switching capacity:
30 Gbps
Forwarding rate:
and Uninterrupted Connection
Dokumen
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-24GT4MS-P-L
Fixed Service Ports
24 ×
4 × 2.5G/1GE SFP ports
2 × 2.5GE/1GE SFP ports
Power modules
1 fixed power module
Fans modules
2 fixed fans
2 fixed fans
1 fixed fans
System Switching capacity
116Gbps
68Gbps
68Gbps
30Gbps
MAC Table Capacity
SDRAM: 512 MB
Flash Memory: 64 MB
< 30 W
< 15.6 W
< 33 W (non-PoE)
< 403 W (PoE full load)
< 16 W (non-PoE)
< 141 W (PoE full load)
≤ 37 dB
≤ 39 dB
≤ 37 dB
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
SSHv1, SSHv2
IGMP V1,V2 snooping
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
TFTP client
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
