Home> Produk> Switch> Access Switches>
RG-S2910-24GT4SFP-UP-H(V3.0)
24-Port Gigabit L2+ Managed POE Switch
The RG-S2910-H series switch, launched by Ruijie Networks, embodies the design of security, high efficiency, and energy saving. It offers full gigabit access and flexible, scalable 10GE uplink data exchange capabilities, making it a next-generation gigabit Ethernet switch. With a new hardware architecture and Ruijie RGOS11.X modular operating system, the switch provides more resource entries, faster hardware processing performance, and better operation experience. The PoE models with different configurations can satisfy access needs of all the downlink ports of the system for PoE load and high bandwidth demand of 10GE uplink.
Feature highlights of RG-S2910-H PoE Switch Series:
● Power Redundancy Support
Lebih banyak+
HPoE
HPoE
Simple Deployment
Shortened construction period
Reduced costs
Simple Deployment
Secure and Reliable
Easy O&M
RG-S2910-24GT4XS-UP-H
RG-S2910-10GT2SFP-UP-H
Up to 256Gbps
Up to 256Gbps
Up to 256Gbps
42Mpps/96Mpps
Up to 96Mpps
Up to 18Mpps
16K
64 (IPv4/IPv6)
In: 1500
Out: 500
In: 1500
Out: 500
In: 750
Out: N/A
Basic QinQ, Flexible QinQ
OpenFlow
VSU Stack Members
Up to 9 stack members
VSL
Layer 3 Features
ARP, IPv4/v6
IPv4 Routing Protocols
Static Routing, RIPng, OSPFv3
GR for RIP
GR for RIP
GR for RIP
Dimensions (W x D x H) (mm)
440×260×44
440×260×44
340×260×44
361712 hours
388055 hours
408710 hours
Common Mode 6KV
Frequency: 50Hz to 60Hz
<460W
<460W
<630W
PoE Power Consumption
Storage humidity: 5% to 95%RH
PoC Guide
Release Note
