176Gbps/336Gbps
Forwarding rate
131Mpps
Dokumen
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
24 x 10/100/1000 BASE-T ports
4 x 1G/10G SFP+ ports
48 x 10/100/1000 BASE-T ports
Fans modules
Power modules
8,000
VLAN translation
4,094
4.3 kg (9.48 lbs)
4.6 kg (10.14 lbs)
3 MB
< 65 W (non-PoE)
< 810 W (PoE full load)
< 75 W (non-PoE)
< 1570 W (PoE full load)
176 V AC to 290 V AC, 1000W
RG-PA600I-P-F:
HVDC: 240 V DC
HVDC: 240 V DC
RG-PA600I-P-F:
HVDC: 192 V DC to 288 V DC
27°C: 51.6 dB
45°C: 57.4 dB
27°C: 51.6 dB
45°C: 58.3 dB
Power port: 6 kV/6 kV
Software S
pecifications
RG-CS83-PD Series
PIM-SMv6, PIM-SSM v6
Traffic policing: CAR
Allowlist
CPP(CPU Protection Policy)
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
