RG-SF2920U-8GT1MS-P Switch - 1
RG-SF2920U-8GT1MS-P Switch - 2
RG-SF2920U-8GT1MS-P Switch - 3
RG-SF2920U-8GT1MS-P Switch - 4
RG-SF2920U-8GT1MS-P Switch - 5
RG-SF2920U-8GT1MS-P Switch - 6
Spesifikasi Penting View More
System packet forwarding rate
16.5 W (without PoE load)
141.5 W (full PoE load)
Warranty period
3 years
More Stable Data Forwarding
2 x 1G/2.5GBASE-T ports
2 x 1GE/10GE SFP+ ports
16 x 10/100/1000BASE-T ports
2 x 1GE SFP ports
2 x 1GE SFP ports
System switching capacity *2
1 MB
256 MB
512 MB DDR3
1.5 MB
56.5 Mpps
76 Gbps
256 MB
512 MB DDR3
1.5 MB
1.18 kg (2.6 lbs)
1.43 kg (3.15 lbs)
1.74 kg (3.84 lbs)
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
2.81 kg (6.19 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
Fixed power supply: 70 W
Fixed power supply: 150 W
The maximum power is 45 W
8.5 W
10 W (without PoE load)
55 W (full PoE load)
25 W (without PoE load)
150 W (full PoE load)
RG-SF2920 Series
Air discharge: 15 kV
Contact discharge: 8 kV
RG-SF2920 Series
RG-SF2920U
RG-SF2920
SPAN, RSPAN and ERSPAN
CWDM
XG-SFP-LR(A1-8)-H
GE-SFP-LR(A1-8)-H
How to ensure safety when installing an SF series all-optical switch in a telecommunication box?
The switch size is smaller than that of the previous generation. The regulation-compliant open area, excellent space layout, and right-angle power plug ensures security. The innovative shark fin design increases the heat dissipation area and improves heat dissipation efficiency, making the operation safer.
395
How to simplify O&M for the SF series all-optical switches?
The switch can be used in combination with the INC controller, to implement fast onboarding, plug and play, and no commissioning. The link fault locating function, together with the INC controller, allows you to check the link health status and alarms, improving the troubleshooting efficiency and achieving zero touch replacement. Traffic routes do not need to change, and different switches can be flexibly used for replacement as required.
391
加载失败
TOP
