Rumah> Produk> Switches > Switch Bare Metal>
B6930-32CDQ2XS Switch
The Ruijie B6930-32CDQ2XS is a new generation high performance and high density 400GbE switch designed for cloud-scale datacenter and campus networks, which provide a powerful cache capacity and advanced scheduling mechanism driven large scale line-rate non-blocking network.
The Ruijie B6930-32CDQ2XS based on Broadcom BCM56980 chipset deliver 32 400GbE QSFP-DD ports in 1RU systems with an overall throughput of 25.6Tbps. The Ruijie B6930-32CDQ2XS support industry standard optics and cables allowing for ease of migration to 400G. All ports allow a choice of speeds including 400GbE, 200GbE or 100GbE, up to 128 interfaces. The Ruijie B6930-32CDQ2XS switch support latency as low as 700ns in cut-through mode, and a 64 MB packet buffer with a large shared pool allowing for superior burst absorption compared to systems with fixed port buffering.
NOTE:
Ruijie B6930-32CDQ2XS is a bare metal switch hardware system with Open Network Install Environment (ONIE). Customer should install networking operation system before use, or contact Ruijie Networks co. for OS support.
Lebih banyak+
Performance
  • 32 × QSFP-DD 400GbE Ports & 2 × SFP+ 10GbE Ports
  • Base on Broadcom BCM56980 (Tomahawk III)
  • Highest density 400GbE in compact 1RU
  • Flexible 100GbE, 200GbE and 400GbE support
  • Up to 25.6 Tbps (full duplex)
  • Up to 8 Bpps
  • Wire speed L2 and L3 forwarding
  • Latency from 700ns for 400GbE (cut-through mode)
Data Center Optimized Design
  • 32 port of 400GbE ports in 1RU
  • Typical power of under 14W per port
  • Over 94% efficient power supplies
  • 1+1 redundant & hot-swappable power
  • 5+1 redundant & hot-swappable fans
  • Front-to-rear cooling
  • Tool less maintenance and simple installation
Cloud Networking Ready
  • 128 ECMP for hyper-scale networks
  • Dynamic Load Balancing for advanced multi-pathing
  • Advanced Congestion Management for NVMe and AI workloads
  • Flow aware traffic scheduling
  • Shared 64MB Buffer with burst absorption
  • Up to 8K MAC and 16K Host entries
  • Over 960K IPv4 Routes
  • Over 960K IPv6 Routes
Resilient Control Plane
  • Intel Xeon D-1527 Processor (Formerly Broadwell DE)
  • 8GB DRAM
Switch Model
B6930-32CDQ2XS
32×QSFP-DD + 2×SFP+
Max 400GbE Ports
32
Max 200GbE Ports
64 (2×200GbE)
Max 100GbE Ports
128 (4×100GbE)
Max 1/10GbE Ports
Throughput (full duplex)
25.6Tbps
Packets/Second
8Bpps
Latency (cut-through mode)
700ns
Intel Xeon D-1527
System Memory
8GB (Up to 32GB)
System Storage
≥64GB
BMC Option
Switch ASIC
Packet Buffer Memory
64MB (Dynamic Buffer Allocation)
10/100/1000 MGMT Ports
RS-232 Serial Ports
1 (RJ-45)
USB Ports
Hot-swap Power Supplies
2 (1+1 redundant)
Hot-swappable Fans
6 (5+1 redundant)
Airflow Option
(Forward and Reversed airflow)
Typical/ Max Power Draw
658W/1183W
Typical/Max Heat Dissipation
2245.7/3754.3 BTU/hr
Size(W×H×D)
17.24×1.70×25.20 in.
(438×43.1×640mm)
29.7 pounds (13.5kg)
Power Supplies
1200W
Standard Compliance
EMC
Emissions: FCC, EN55022, EN61000-3-2, EN61000-3-3 or EN61000-3-11, EN61000-3-12 (as applicable)
Immunity: EN55024
Emissions and Immunity: EN300 386
UL/CSA 60950-1, EN 60950-1, IEC 60950-1 CB Scheme with all country differences
Certifications
North America (NRTL)
European Union (EU)
BSMI (Taiwan)
C-Tick (Australia)
CCC (PRC)
MSIP (Korea)
EAC (Customs Union)
VCCI (Japan)
European Union Directives
2006/95/EC Low Voltage Directive
2004/108/EC EMC Directive
2011/65/EU RoHS Directive
Power Supply Specifications
1200W
Input Voltage
100-240V AC
240V DC
Typical Input Current
12-7A (AC)
6A (DC)
Input Frequency (AC)
50~60Hz
Input Connector
IEC 320-C13
Efficiency (Typical)
94% Platinum
Environmental Characteristics
32 to 104° F (0 to 40°C)
-40 to 158° F (-40 to 70°C)
Relative Humidity
5 to 95% non-condensing
Altitude (Operating)
Designed to meet: 0 to 10,000ft
Altitude (Non-operating)
-1000ft to 30,000ft
B6930-32CDQ2XS
32 fixed 400G QSFP-DD ports, 2*10G SFP+ ports.
6 slots for fan modules.
2 power supply modules and 6 fan modules already included.
B6930-40FAN-F
Fan module, front-to-rear airflow.
With up to 6 fan modules, support 5+1 redundancy.
RG-PA1200I-F
Power supply module, front-to-rear airflow.
With up to 2 power modules, support 1+1 redundancy.
Ruijie Networks
About Cookies on this site
