•Efficient management using Ruijie Cloud, Web-UI and command lines
•Enterprise grade QoS, security and management features;
•L3 features enables working in SMB campus core layer;
•Unique security features like CPP and NFPP ensure network safety with smart counter measures;
•Unique Smart+ features for CCTV networks.
The XS-S1960 Series PoE switches support 802.3bt HPoE standards to offer up to 60-watt per port and a 370-watt high-power budget. All of the access ports support POE+ output, to meet the connectivity needs of more power-hungry devices.
With Conformal Coating for 2 years
No obvious corrosion was found after cleaning
Without Conformal Coating for 1 month
Rusted chip pins and resistor whiskers were found after cleaning
Special coating material painted on the PCBA
Excellent performance in being insulating,damp proof,dust proof, anti-corrosion, mold proof, and salt-spray resistant
Compliant with IEC60068-2-60 International Standard
Managed at Ruijie Cloud platform, providing anytime anywhere mobile monitoring and troubleshooting, making the plug and play of network management devices possible.
A fully functional built in Web-GUI allows operation to be intuitive and convenient.
Industry Standard Command Line Interface (CLI) makes customer configuration and troubleshooting easier.
Advanced Layer 2 and Layer 3 basic features are supported which are necessary for an access or core switch of SME.
The XS-S1960 Series Switches are tailor-made for ELV & Surveillance Monitoring scenarios. Features like full PoE out, 6KV Lightning Protection, Large Buffer and Non-blocking Architecture are essential for reliability and stability of 24x7 operation.
PoE+ On All Ports
Operation Temperature 0°C- 50℃
12Mbit Large Buffer
About Cookies on this site
