Product Model | XS-S1920-9GT1SFP-P-E | XS-S1920-26GT2SFP-P-E | XS-S1920-26GT2SFP-LP-E | XS-S1920-24T2GT2SFP-P-E | XS-S1920-24T2GT2SFP-LP-E | RG-S1920-18GT2SFP | RG-S1920-24GT4SFP/2GT |
Ports | 10/100BASE-T | n/a | n/a | n/a | 24 | 24 | n/a | n/a |
10/100/1000BASE-T | 9 | 26 | 26 | 2 | 2 | 18 | 26 |
1000M SFP | 1 | 2 | 2 | 2 | 2 | 2 | 4 (with 2 combo) |
Power over Ethernet | PoE | ✓ | ✓ | ✓ | ✓ | ✓ | n/a | n/a |
PoE/PoE+ | 8 | 24 | 24 | 24 | 24 | n/a | n/a |
IEEE802.3af | ✓ | ✓ | ✓ | ✓ | ✓ | n/a | n/a |
IEEE802.3at | ✓ | ✓ | ✓ | ✓ | ✓ | n/a | n/a |
PoE Power Budget | 125W | 370W | 185W | 370W | 185W | n/a | n/a |
Physical | Packet Buffer | 4.1Mbit | 4.1Mbit | 4.1Mbit | 4.1Mbit | 4.1Mbit | 4.1Mbit | 4.1Mbit |
CPU Memory | 256MB | 256MB | 256MB | 256MB | 256MB | 256MB | 256MB |
Flash | 32MB | 32MB | 32MB | 32MB | 32MB | 32MB | 32MB |
Dimensions(WxDxH) | 300x220x43.6mm | 440x292x43.6mm | 440x292x43.6mm | 440x292x43.6mm | 440x292x43.6mm | 440x189x43.6mm | 440x189x43.6mm |
Surge Protection | 8KV | 8KV | 8KV | 8KV | 8KV | 10KV | 10KV |
Unit Weight | 2kg | 4.2kg | 4.2kg | 4.2kg | 4.2kg | 2.4kg | 2.4kg |
Power Supply | Type | Internal | Internal | Internal | Internal | Internal | Internal | Internal |
Frequency | 50/60Hz |
AC Voltage | 100~240V |
Maximum Power Rating | 145W | 430W | 226W | 424W | 215W | 17W | 22W |
Cooling | Fanless | Fan | Fan | Fan | Fan | Fanless | Fanless |
Certifications | Safety | EN 60950-1 | EN 62368- 1 |
EMC | EN 300 386 |
Emissions | EN 55032, EN55035 |
ESD | EN 61000-4-2 |
Radiated | EN 61000-4-3 |
EFT/Burst | EN 61000-4-4 |
Surge | EN 61000-4-5 |
Conducted | EN 61000-4-6 |
Power frequency magnetic field | EN 61000-4-8 |
Voltage dips and interruptions | EN 61000-4-11 |
Harmonics | EN 61000-3-2 |
Flicker | EN 61000-3-3 |
RoHS | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
EEE | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
Operating Temperature | -5 ℃ ~ 55 ℃ |
Storage Temperature | -40 ℃ ~ 70 ℃ |
Opertaing Humidity | 10%~90% RH |
Storage Humidity | 5%~95% RH |
Operating Altitude | -50m ~ 5000m |
Warranty | 3-Year Warranty Free of Charge |
Package Contents | Ruijie XS-S1920-E/RG-S1920 Series Switch |
Performance | Switching Capacity | 20Gbps | 56Gbps | 56Gbps | 12.8Gbps | 12.8Gbps | 40Gbps | 56Gbps |
Forwarding Rate | 15Mpps | 42Mpps | 42Mpps | 9.6Mpps | 9.6Mpps | 30Mpps | 42Mpps |
L2 Switching | MAC Table Size | 8K | 8K | 8K | 8K | 8K | 8K | 8K |
STP | ✓ |
RSTP | ✓ |
MSTP | ✓(63 instances) |
Port Grouping | LACP |
VLAN | IEEE802.1Q |
GVRP | ✓ |
IGMP Snooping | ✓(v1/v2/v3) |
Jumbo Frame | 9KB |
L3 | IPv4 Routing | Static/RIP (in future release) |
IPv6 Routing | Static/RIPng (in future release) |
DHCP Client | ✓ |
Security | CPP | ✓ |
SSH | ✓ |
SSL | ✓ |
Storm Suppression | ✓ |
Port Protection | ✓ |
ACL | ✓ |
Reliability | RLDP | ✓ |
DLDP | ✓ |
Management | Web User Interface | ✓ |
HTTP/HTTPS | ✓ |
Ruijie Cloud Management | ✓ |
RG-SNC Management | ✓ |
Command Line Interface | ✓(Telnet/Console) |
SNMP | ✓ |
Smart+ for CCTV | ✓(Auto Smart Deployment/Remote Reboot Helper) | n/a |
SYSLOG | ✓ |
NTP | ✓ |
Public MIBs | ✓ |
Private MIBs | ✓ |
RMON | ✓(1/2/3/9) |
Firmware Upgrade | ✓ |
Port Mirroring | ✓ |
Model | Description |
XS-S1920-24T2GT2SFP-P-E | Smart Managed Switch, 24 10/100BASE-T ports, 2 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 370W |
XS-S1920-24T2GT2SFP-LP-E | Smart Managed Switch, 24 10/100BASE-T ports, 2 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 185W |
XS-S1920-26GT2SFP-P-E | Smart Managed Switch, 26 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 370W |
XS-S1920-26GT2SFP-LP-E | Smart Managed Switch, 26 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 185W |
XS-S1920-9GT1SFP-P-E | Smart Managed Switch, 9 10/100/1000BASE-T ports, 1 1000M SFP ports, AC power supply, support PoE/ PoE+, PoE power budget: 125W |
RG-S1920-18GT2SFP | Smart Managed Switch, 18 10/100/1000BASE-T ports, 2 1000M SFP ports, AC power supply |
RG-S1920-24GT4SFP/2GT | Smart Managed Switch, 24 10/100/1000BASE-T ports, 4 1000M SFP ports (With 2 combo ports), AC power supply |
About Cookies on this site
